Gln
Hi @ramkumarkoppu​ ,
The code in the video can be found here: https://colab.research.google.com/drive/1lBca6J1kUTNG8MmaM_TTPV8M-5IXdy7Y . This Colab notebook goes over the different steps described in the video (Gathering and exploring data, preprocessing, model creation and trainning).
'import tutacousticscnees2016' is refering to some custom code to download the TUT Dataset. If using the Colab notebook mentioned above, the code is downloaded at the very beggining, otherwise, you can manually download the code from her: https://gist.github.com/glegrain/13276fb57007905180f5455be7a3d6cd
Regards,
Guillaume
ramkumarkoppu
Thank you.
Aase.2
January 4, 2021
Looking for the same code solution for my python project that hosted online.
