Dec 4, 2024 3:17 AM UTC
Problem when moving a github project model to stm32cube AI
First , the github project is this
https://github.com/Xiaobin-Rong/gtcrn/tree/main
It has converted to onnx and tensorRT for ppl to use
but when i load the onnx model into stm32 for optimize/import (setting , compression : none , optimization : balance)
it just jumps out an error
X-cube-AI version is 9.1.0
ST Edge AI Core v1.0.0-19894
INTERNAL ERROR: Trying to remove node_339 which has multiple inputs
is it because the multi input and output network limitation or something else?
and if i success to import this model
how to deal with the multi dimensional  tensor arrays that the github author demo ?
if you want to test on the model
there is the link for the onnx and tensorRT model
https://github.com/Xiaobin-Rong/TRT-SE/tree/main/online/models
Thanks in advance
Uveuvenouve
Julian E.
Julian E.Best answer
Dec 4, 2024 9:46 AM UTC
Hello @uveuvenouve,
The issue here is that bidirectional LSTM are not supported in ST Edge AI
You can see below that your node_339 is the bidirectional LSTM:
You can find the list of supported ONNX operator in the ONNX toolboox page in the CubeAI Documentation:
https://wiki.st.com/stm32mcu/wiki/AI:X-CUBE-AI_documentation#X-CUBE-AI_embedded_documentation_access
Concerning the LSTM:
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Julian E.
Hello @uveuvenouve,
Have a good day,
Julian
Dec 4, 2024 10:40 AM UTC
Thank you
