Julian E.Best answer
Mar 27, 2025 1:21 PM UTC
Hello
Yes indeed, it is hard to tell.
In the X Cube AI menu, you can click setting and set --verbosity 3:
But I don't think it is enough.
What you should do is use stedgeai.exe manually.
When you do a validate in X Cube AI, it literally does:
stedgeai.exe generate --model your_model --target stm32n6 --st-neural-art
So you can open a bash terminal and do this manually but you also need to first do:
export _DEBUG=2
to have more logs.
Have a good day,
Julian
