Jan 23, 2025 3:18 AM UTC
NanoEdge AI Studio training process gets stuck
Hi Supporter:
     I attempted to train a model using NanoEdge AI Studio,Some errors occurred!
    first,I create a NC-class project (ps:I haven't connected the development board. I'm just using the computer for simulation.)
add signal
benchmark
When I clicked "Start," the screen stuck on this page and stayed there all day, only to be closed through the task manager.
What's the problem?
Julian E.
Julian E.Best answer
Jan 23, 2025 8:24 AM UTC
Hello @PP_Developer ,
Everything seems correct at first glance.
Please try to restart your computer to make sure everything related to NanoEdge is closed
Uninstall NanoEdge
Install NanoEdge again.
Sometime, during the installation / update, there are issues due to non-closed elements.
Please keep me updated.
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Julian E.
Uninstall NanoEdge
Have a good day,
Julian
Jan 23, 2025 9:17 AM UTC
The outcome is the same, whether it is restarting the computer or reinstalling the software.
I guess there might be the following several possibilities.
1.Network issue. Is it because I can't access your model library from my end? Could you provide me with a URL or domain name of the model library so that I can ping it?
2.Regarding the issue of permissions, I applied for the serial code through the email. Is it because of insufficient permissions?
3.Regarding the computer configuration issue, do you have any requirements for the configuration of the computer? For example, regarding the memory?
Julian E.
Jan 23, 2025 9:34 AM UTC
Can you send me the log files in a zip please:
  • Click on the icon as in the screenshot in the bottom left corner.
Network issue may cause error but later in the process.
You don't need permission
As for requirements make sure to have free disk space but that's it...
Julian
