Yes you can go to deployment directly after the benchmark.
The validation is made to make sure that the library selected during the benchmark is indeed the best one. To do that we use the validation to test multiple libraries on new data
The emulator is also there for this purpose. It is made to test more robustly a specific library.
Here is an example of how learning on device could be interesting.
You have 100 machines, but you don't want to log data on every single one machine. You can log data on let say 2 to 10 machines. Use Nanoedge to find the best library and then deploy the same library on every machines. But in your C code, you will have a part to log few learning signals and retrain the library before doing detection. It allows each library to be more specifically train for each machine.
Best regards
Julian
