Aug 24, 2024 8:57 PM UTC
model zoo Object detection
I want to implement an application for detecting items in the kitchen on an STM32-H747i-DISCO board. I installed Python 3.10.2, TensorFlow 2.8, CUDA 11.7, and cuDNN v8.8.1. After installing the model zoo , I tried running the command in  Command Prompt python stm32ai_main.py , from this path " ..\stm32ai-modelzoo\object_detection\src".  But I encountered the attached error
I
Laurent FOLLIOT
Laurent FOLLIOTBest answer
Sep 2, 2024 8:27 AM UTC
As this is path related issue, could you create a new virtual environment either with Conda or python?
This should avoid such issues.
Thanks & Regards,
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Laurent FOLLIOT
Aug 28, 2024 9:26 AM UTC
Could you share your yaml file please?
We do not reproduce the issue as this time on last model zoo version.
Regards,
MH24Author
Aug 28, 2024 2:17 PM UTC
Attached is the yaml file
Thank you
Laurent FOLLIOT
Aug 28, 2024 2:32 PM UTC
Thanks,
Do you confirm that you cloned the repository from GitHub, without code modification and that preprocess.py file is well cloned in src/preprocessing folder?
MH24Author
Sep 1, 2024 9:03 AM UTC
yes I confirm
Laurent FOLLIOT
Thanks & Regards,
