Apr 26, 2026 13:06 UTC
May I ask, the model uses the torch.mul() operator, and when the model is saved in ONNX format and uploaded to ST Edge AI, it fails to parse. Ho
mƎALLEm
Apr 26, 2026 13:29 UTC
Hello @shua and welcome to the ST community,
Please review How to write your question to maximize your chances to find a solution
Especially this point:
I invite you to edit your post accordingly.
Thank you for your cooperation.
Julian E.
May 4, 2026 08:46 UTC
Hi @shua,
It most likely depends on your model.
For non-accelerated hardware, you can find the list of supported layers here (for onnx), and in your case mul:
https://stedgeai-dc.st.com/assets/embedded-docs/supported_ops_onnx.html#mul
If you are using a NPU (n6 for example):
https://stedgeai-dc.st.com/assets/embedded-docs/stneuralart_operator_support.html#title
 Make sure to respect the conditions listed
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
