May 6, 2021
Implementation of lambda layer
- 1 reply
- 970 views
Hello
I am trying to implement an RNN which contains a lambda layer. It works perfectly on keras but gives me an error in STM32CubeIDE
I have read in the documentation that it should be possible to implement a lambda layer in the X-CUBE-AI 6.0.0 and followed the advice there but nothing works.
The lambda layer I am trying to implement is:
x2=layers.Lambda(lambda q: q[:, -1])(x)
Which basically takes just one column from another layer.
Do you know how can I implement this layer or maybe a workaround using another kind of trick?
