BFaru.1
I have X-CUBE-AI version 7.3 installed. Is it possible to backtrack it and use version 5.1.2 of X-CUBE-AI library? Because I dont see any option in the dropdown menu of "Select Components" to choose version earlier than 7.3.
    fauvarque.daniel
    fauvarque.danielBest answer
    In STM32CubeMX if you have both versions installed you can start a new project and choose the version when adding the X-Cube-AI pack.
    I recommend to quit STM32CubeMX before to start a new AI project with a previous version.
    Sometime the correct AI plugin is not loaded by STM32CubeMX when you change versions
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
    fauvarque.daniel
