AGabr.1
November 8, 2022
I get this error on NanoEdge Ai Studio. Unable to compile datalogger : Connection failed to compilation server, due to 401 / User does not have permission to compile Product is regurarly actrivated.
Logs are attached. Board is STEVAL-PROTEUS1
Julian E.
Hello @AGabr.1​,
Thank you for reporting this problem. The error has been corrected and you should now be able to use the datalogger.
Best Regards,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
