TShun.1
I can't program FP-AI-MONITOR binary.
  • January 30, 2023
  • 1 reply
  • 2314 views
I am trying AI-MONITOR1 using STWIN Starter Kit.
I am referring to the URL below.
AI:FP-AI-MONITOR1 �?��?��?�?� - STM32MCU
Section 2.3.2 states that the application is flashed on the sensor board, but it cannot be programmed because the memory capacity is not enough for the binary.
Is it necessary to prepare an external memory?
    gokugo
    Explorer
    February 3, 2023
    @TShun.1​ make sure you connect STWIN to your laptop first, then connect ST-LINK. Otherwise, you will see only 32KB like in your screenshot, which is the memory on ST-LINK.
