Apr 10, 2025 8:43 AM UTC
How to use the extended Flash on X-CUBE-AI
I'm running low on FLASH, and I'm confused about extensions.May i ask if there are any routines or tutorials available?
hamitiya
hamitiyaBest answer
Apr 11, 2025 5:59 AM UTC
Hello
In order to use external flash with X-CUBE-AI, you can find in X-CUBE-AI panel:
- Advanced Settings
- "External Flash" tab
And you can set the external flash start address and how you should split your weights. Different methods exist like a separate bin with your weights.
You can find more details here (page 21)
Getting started with X-CUBE-AI Expansion Package for Artificial Intelligence (AI) - User manual
Best regards
Yanis
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
pienascAuthor
Apr 10, 2025 8:54 AM UTC
Now it's like this, I have extended W25Q128 chips, but I don't know how to write code to connect them
hamitiya
hamitiyaBest answer
Hello
- Advanced Settings
Best regards
Yanis
