How to read the MLC0_SRC Register properly on LSM6DSOX
I am trying to use the MLC on the LSM6DSOX with the 6D Position Recognition Sample.
The Interrupts on INT1 are triggered as expected, but when I read the MLC0_SRC (0x70U) it always returns 0. Moreover, I tried different samples - same problem.
I was able to read other registers, for example the TAP_SRC where the data is properly returned. (Double Tap/Single Tap)
So, is there a difference in reading the MLC0_SRC and TAP_SRC except the address?
Thanks in advance,
Manuel
