APerd.1
How to fix "INTERNAL ERROR: list index out of range" when uploading an onnx model to STM32Cube.AI
Hello!
I'm getting the error: INTERNAL ERROR: list index out of range when uploading an onnx model to STM32Cube.AI and run analysis. I have validated my model with other tools like netron.app and it is correct. I would appreciate if anyone could help to figure out what could be the problem? I attach my model below in case someone can help me. Thanks in advance. Regards!
    APerd.1
    APerd.1Author
    I forgot to mention that this model was generated in Matlab with exportONNXNetwork function, in case it may be of help.
    fauvarque.daniel
    The error is in the import of the LSTM layer, probably due to the way Matlab exports the LSTM layer.
    I forwarded the network to the development team.
    Daniel
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
    APerd.1
    APerd.1Author
    Thanks! I would appreciate any feedback on the matter, cause I need to use lstm layers for my project.
    Regards.
    Alejandro
    APerd.1
    APerd.1Author
    Hi @fauvarque.daniel​. Hope you're fine.
    Any feedback from the development team on the error in the import of the LSTM layer? I would appreciate any solution proposal to the problem.
    Alejandro
    fauvarque.daniel
    Issue has been reproduced and fix is ongoing, normally the fix will be part of the next 8.1 release planned in June
    Daniel
    APerd.1
    APerd.1Author
    Thanks for your reply.
    Alejandro
    wg_it
    I have met the same problem. Have you solved it? Thank you very much
    APerd.1
    APerd.1Author
    Hello @武 钢​
    No, I could not solve the problem. I expect the problem to be fixed for the next 8.1 release planned in June. @fauvarque.daniel​ reported the problem and fix is ongoing.
