BDa S.1
How to connect the steval mki207v1 and F401RE
  • November 17, 2022
  • 1418 views
Good afternoon,
May be I'm gonna to ask you a bad question. I want to know if it's possible to connect the F401RE with the steval mki207v1 without an IKS board.
Thanks for your answers.
Have a good day
    Julian E.
    Hello @BDa S.1​ ,
    Thank you for your question. Indeed, you can connect the MKI207v1 to your NUCLEO. You need to do the following connections:
    • Bus: i2c <=> I2C1 (PB8, PB9)
    • Interrupt line: INT1 <=> PC0
    Best regards,
    Have a good day
    ​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
    BDa S.1
    BDa S.1Author
    Thank you for you help
