THey
Jun 18, 2019 5:31 AM UTC
How to add the AI "x-cube-ai" package toSTM32IDE (Not CubeMX)
I have installed the latest STM32IDE (V1.0.1) but I cant see how to add the x-cube-ai package. The suggested method is to use the "Help Menu" -> Manage Embedded software packages" but this is greyed out. I also tried using Help->Install new software, I downloaded the "en.x-cube-ai.zip" package and tried to specify it as alocal install, bu this gives errors too.
Yuk117
Yuk117Best answer
Jun 19, 2019 11:05 AM UTC
I resolved same problem.
Open any STM32 project, then "Manage Embedded software packages" will be enabled.
Yuk117
Yuk117Best answer
THey
THeyAuthor
Jun 19, 2019 4:43 PM UTC
Thanks that is correct way
