niccolò
Hi @bcryhun ,
it may depend on the firmware installed on the STWIN. can you check which is it?
this is the first I would try to work with WiFi:  FP-AI-PREDMNT2
If this answers your question, please, mark this as "best answer", by clicking on the "accept as solution" to help the other users of the community
Niccolò
bcryhunAuthor
i did use fp-ai-predmnt2 and follow steps on documentation. It is same, i can not connect to wifi. When i try to write ssid and password, it does not give any response
niccolò
Hi @bcryhun ,
what toolchain did you use?
were you able to check with debug if the fw has some problem somewhere?
if you tell me where it gets stuck I can try to help you overcoming this issue =)
Niccolò
