May 5, 2025 9:15 PM UTC
FP-AI-VISION1 FoodReco
I was trying to figure out how to use external memory and flash with xcubeai, and I found a video posted by STM32 says there is an example food recognition code in stm32ai-modelzoo-services on Github. However, I couldn't find it. Was it deleted?
thanks.
Edouard Dulau
Edouard DulauBest answer
May 6, 2025 9:42 AM UTC
Edouard Dulau
Oct 15, 2025 10:49 AM UTC
That’s a really interesting discussion on food recognition with STM32 and X-CUBE-AI! I recently came across a similar setup using AI for identifying food items, and it’s quite inspiring to see how edge AI applications are evolving. You can check a related example I found here: — it also explores food-based data processing
Feb 23, 2026 11:32 AM UTC
FP-AI-VISION1 FoodReco is an innovative solution in food recognition technology, enabling users to quickly identify, track, and analyze meals using AI. Tools like this make it easier to manage nutrition, discover new foods, and even streamline ordering in restaurants. Similarly, for those exploring dessert and drink options in NYC, platforms like Mixue NYC Menu provide up-to-date Mixue menu items, prices, and locations, helping you make informed and delicious choices with ease.
Aug 25, 2026 10:10 PM UTC
Thanks for sharing this. Food recognition is a really interesting use case for edge AI, especially when running models directly on an STM32 device. It would be helpful if the example from the video was moved to a clearly documented location or if there were notes explaining whether it was renamed or removed. I’m also curious whether there’s a recommended alternative example for handling external flash and memory with xcubeAI, since that would make experimenting with food-recognition projects much easier.
Visitor
Nov 7, 2026 5:32 PM UTC
You could check the available examples in the STM32 Model Zoo repository and its documentation, as some projects may have been reorganized or moved. I usually find it helpful to compare different food options and ingredients before making a choice
