Jul 18, 2024 10:08 AM UTC
facing trouble in how to use the generated code by cube ai 9.0
hello everyone , i'm a newbie at edge ai in stm32 and i'm using cube ai 9.0 .i want to get information in how to use "MX_X_CUBE_AI_Process() " and "MX_X_CUBE_AI_init()" , i didn't find documentation or something about what the function does , what's to give as input and what/where do i get the output. i'm prediction an image and the output is 2 classes.
thanks for any information.
fauvarque.daniel
Jul 23, 2024 11:33 AM UTC
This is described in the documentation embedded in the package
~/STM32Cube/Repository/Packs/STMicroelectronics/X-CUBE-AI/9.0.0/Documentation/embedded_client_api.html
You can access the documentation directly with STM32CubeMX, on a project with AI enabled just go in Help->X-Cube-AI Documentation and then click on  Embedded inference client API
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
