Oct 30, 2024 12:36 PM UTC
Error when exporting Onnx model "NOT IMPLEMENTED: Order of dimensions of input cannot be interpreted"
I am currently using the STM32 Edge AI Developer Cloud to convert my ONNX model, which I built using PyTorch.
The ONNX model is attached for your reference.
I would greatly appreciate your guidance on this matter, as it is blocking my research.
Thank you for your assistance.
hamitiya
hamitiyaBest answer
Oct 30, 2024 1:47 PM UTC
We are aware of a similar issue, and it will be fixed in our next release of ST Edge AI Developer Cloud.
Best regards,
Yanis
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
hamitiya
hamitiyaBest answer
Best regards,
Yanis
Fra_Author
Oct 31, 2024 9:49 AM UTC
I think this issue is also in X-CUBE-AI, right?
hamitiya
Nov 7, 2024 9:50 AM UTC
Sorry for late reply, yes this issue is also in X-CUBE-AI since they both rely on the same command-line. They both will be updated with new command line interface which will fix the problem you raised.
Best regards,
Yanis
Dec 12, 2024 12:43 PM UTC
I wonder if this problem has already been fixed in X-Cube-AI 10.0.0?
hamitiya
Dec 12, 2024 1:07 PM UTC
Hello @Lemanoise,
The error previously raised in this topic is fixed with the latest version of X-CUBE-AI 10.0.0 and the release available in ST Edge AI Developer Cloud.
Best regards,
Yanis
