Jan 2, 2025 1:55 PM UTC
Error Neural-ART Accelerator MCU: "INTERNAL ERROR: Scale, zero-point, and quantizer must be set simultaneously"
This ONNX model is compiled with a standard MCU and runs on it (both with and without quantization). However, I encounter the following error when using the Neural-ART Accelerator NPU (both with and without quantization):
INTERNAL ERROR: Scale, zero-point, and quantizer must be set simultaneously.
It seems to me that all the model's onnx operations are supported (https://stedgeai-dc.st.com/assets/embedded-docs/stneuralart_operator_support.html)
Julian E.
Julian E.Best answer
Jan 9, 2025 8:27 AM UTC
Hello @Fra_ ,
After investigation, the issue is caused by the equal layer. We opened a ticket internally to fix it.
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Julian E.
Jan 6, 2025 4:17 PM UTC
Hello @Fra_,
Can you share the model in a .zip file?
Have a good day,
Julian
Fra_Author
Jan 6, 2025 7:34 PM UTC
Julian E.
Hello @Fra_ ,
Have a good day,
Julian
