Dec 12, 2024 12:48 PM UTC
Error analysing LSTM model using X-Cube-AI: ""NOT IMPLEMENTED: Order of dimensions of input cannot be interpreted""
As stated, I have problem analyzing the ONNX model ported from a pytorch model. The code of the model is simple as follows:
class LSTM(nn.Module):
 def __init__(self, input_size, hidden_size, num_layers, num_output=1):
 super(LSTM, self).__init__()
 self.num_layers = num_layers
 self.input_size = input_size
 self.hidden_size = hidden_size
 self.num_output = num_output
 self.lstm = nn.LSTM(input_size=input_size, hidden_size=hidden_size,
 num_layers=num_layers, batch_first=True)
 self.fc = nn.Linear(hidden_size, num_output)
 def forward(self, x, device='cuda'):
 ula, (h_out, _) = self.lstm(x)
 out = self.fc(h_out[-1])
 return out
 Netron vis:
I will really appreciate any advice or workarounds. Thank you!
Julian E.
Julian E.Best answer
Dec 16, 2024 1:26 PM UTC
Hi everyone,
I did some test on my side and we currently only support LSTM with 1 hidden size and 1 layer. Something like:
import torch
import torch.nn as nn
# Simple lstm that works
 num_layers=num_layers, batch_first=True, bidirectional=False)
 return out
# If not 1 : error
# other parameter we can put anything
input_size = 10
hidden_size = 1
num_layers = 1
num_output = 10
model = LSTM(input_size, hidden_size, num_layers, num_output)
model.eval()
dummy_input = torch.randn(1, 128, input_size)
onnx_file_path = "simple_lstml.onnx"
torch.onnx.export(model, dummy_input, onnx_file_path,
 input_names=['input'], output_names=['output'])
I tried to stack multiple LSTM but I had no success.
I am asking for more information, I will keep you updated
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Julian E.
Dec 12, 2024 3:35 PM UTC
Hello @Lemanoise,
Can you attach your onnx model in a .zip file please?
In the meantime, make sure you follow the conditions described in the ONNX Toolbox documentation concerning the LSTM:
LSTM
Computes a multi-layer long short-term memory (LSTM) RNN to an input sequence (batch=1, timesteps, features)
  • category: recurrent layer
  • input data types: float32
  • output data types: float32
Specific constraints/recommendations:
  • stateless mode support only
  • fused activation: sigmoid
  • fused recurrent activation: sigmoid
  • return_state not supported
  • Only 1 input is allowed for LSTM; the others should be constant and placed into the initializers
  • layout=1 attribute is not supported
https://stedgeai-dc.st.com/assets/embedded-docs/supported_ops_onnx.html
Have a good day,
Julian
LemanoiseAuthor
Dec 13, 2024 2:54 PM UTC
Yeah sure, here is the onnx model. Thank you for your advice and I'll look into it as well.
Dec 16, 2024 7:30 AM UTC
Hello,I have the same question.Do you slove this question?
LemanoiseAuthor
Dec 16, 2024 8:55 AM UTC
No not yet, I hope ST staffs will check my model and give us further guidance.
Julian E.
Hi everyone,
import torch
 return out
# If not 1 : error
input_size = 10
hidden_size = 1
num_layers = 1
num_output = 10
model.eval()
Have a good day,
Julian
LemanoiseAuthor
Dec 16, 2024 3:35 PM UTC
Thank you! I have tried the one-layer case and it succeeded. Please keep sharing further information on multi-layer case if any :)
Julian E.
Dec 16, 2024 4:32 PM UTC
Hello  @Lemanoise ,
Using tensorflow, I could use multiple LSTM one after the other (which I did not succeed to do with pytorch).
It may be useful for you:
import tensorflow as tf
from tensorflow.keras.models import Model
from tensorflow.keras.layers import Input, LSTM, Dense
input_layer = Input(shape=(100, 2), batch_size=1)
lstm1= LSTM(32, activation='relu', stateful=True,return_sequences=True)(input_layer)
lstm2 = LSTM(32, activation='relu', stateful=True,return_sequences=True)(lstm1)
output_layer = Dense(units=3, activation='linear')(lstm2)
# Create the model
model = Model(inputs=input_layer, outputs=output_layer)
# Print the model summary
model.summary()
# Compile the model
model.compile(optimizer='adam', loss='mean_squared_error')
model.save('tf_lstm.h5')
Be careful to follow these instructions while using it:
https://stedgeai-dc.st.com/assets/embedded-docs/keras_lstm_stateful.html
Have a good day,
Julian
LemanoiseAuthor
Dec 18, 2024 3:31 PM UTC
Thank you very much!
Julian E.
Dec 20, 2024 9:10 AM UTC
Hello @Lemanoise,
I should know more about how to use LSTM properly with ST Edge AI Core on the start of next year.
But for the moment I managed to use more than one hidden size with pytorch by not using the batch_first option:
import torch
 num_layers=num_layers, batch_first=False)
 return out
# If not 1 : error
# other we can put anything
input_size = 10
hidden_size = 10
num_layers = 1
num_output = 10
model.eval()
dummy_input = torch.randn(1, 128, input_size) # Batch size 1, Sequence length 128, Input size 10
It may help you
Have a good day,
Julian
