Jun 18, 2025 6:27 AM UTC
cubeMX10.1.0 Generate code exception issue
1.I chose not to generate calls when generating code in cubemx, but it actually needs to be generated. Also, this cubemx is written in Java and always pretends to be dead. My computer is a high-end Intel i9, so it's impossible for the software to run slowly
2.I chose high compression, but it didn't work
Julian E.
Jun 18, 2025 7:25 AM UTC
Hello @奥特曼9527,
I think you can select none as template when activating X Cube AI to solve your issue.
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Jun 19, 2025 5:33 AM UTC
I find it hard to accept your statements. Your BUG is just left untouched and not modified. It's too annoying.
Julian E.
Jun 19, 2025 7:41 AM UTC
Hello @奥特曼9527,
What target are you using?
Also, what do you mean when saying " Also, this cubemx is written in Java and always pretends to be dead"? Do you mean that the software is slow and freezing?
Why did you post a screenshot of the compression option?
Have a goodd day,
Julian
