jayz
March 12, 2019
CUBE-MX
    JNord
    Hi JayZ.
    The FP-SENSING-AI1 package contains example code for classifying accelerometer using a neural network.
    https://www.st.com/en/embedded-software/fp-ai-sensing1.html
    The example code runs directly on the SensorTile hardware, so that is the easiest way to get started. You can use the Sdcard or USB to a computer to collect your training data.
    https://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/sensor-solution-eval-boards/steval-stlkt01v1.html
    For your first model, you can try to reuse the basic HAR model included in FP-AI-SENSING1. In general, a CNN or recurrent (LSTM,GRU) model is commonly used for these kinds of problems.
    Also check this nice tutorial with some example data, https://developer.ibm.com/tutorials/iot-deep-learning-anomaly-detection-5/
    Cheers,
    Jon Nordby
    Machine Learning Engineer & Independent Consultant
