Jul 23, 2025 7:49 AM UTC
Crash Debugging on STM32N6-DK: ATON_ENABLE(EPOCHCTRL)
I am using the STM32N6-DK board.
I am trying to execute an AI model on the STM32N6-DK board, following the instructions on the website below.
How to run AI models from model zoo on STM32N6 - STMicroelectronics Community
However, the software crashes when I try to execute it.
After examining the process, it seems to fail at the following sequence of function calls:
c
LL_ATON_RT_Main(&NN_Instance_Default);
LL_ATON_RT_RunEpochBlock(network_instance);
__LL_ATON_RT_ExecStartEpochBlock(nn_instance->exec_state.current_epoch_block, nn_instance);
ATON_ENABLE(EPOCHCTRL, ecId);
misaki_1-1753256758460.pngmisaki_2-1753256789503.pngmisaki_3-1753256824725.pngmisaki_4-1753256887386.png
The crash occurs after calling
What could be the potential causes for this problem?
Julian E.
Jul 23, 2025 1:23 PM UTC
Hello @misaki,
You just downloaded the getting started, opened the cubeide project and flashed it?
Or are you trying to use another model? Could you please describe the steps you followed.
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
misakiAuthor
Jul 24, 2025 1:09 AM UTC
Hello @Julian E.
I followed all the steps described on this website (How to run AI models from model zoo on STM32N6 - STMicroelectronics Community).
When I performed the final step and ran the process in CubeIDE, the execution crashed.
To investigate the cause, I ran a debug process in CubeIDE and found that it crashed at the specific location mentioned above.
Thank you for your support.
