Junde
Senior III
June 14, 2024
compiler error after add cubeAI by cubeMx
Hi there,
I have a work-well project with TouchGFX and FreeRTOS.
After I enable the CUBE-AI software pack(can't check the application),
and compiler the project, the error as below(there are 2 same RW_RAM):
After commenting one RW_RAM and compiler again, the error was as follows:
I don't know what happened and how to resolve it, can someone help me?
Thanks for your help!
Muhammed Güler
Senior III
June 14, 2024
Could you be compiling the project without selecting the network?
You should choose a network trained with keras and let the cube ai tool create the necessary files.
Junde
JundeAuthor
Senior III
June 14, 2024
@Muhammed Güler
Thanks for your reply!
I already add the network in cubeMx:
The attachment is the analysis report, if you need to check it.
BTW, the network was downloaded from HERE.
