ksale.1
Senior II
June 21, 2024
Code Generator File structure of ver 9.00 AI Package
  • June 21, 2024
  • 1 reply
  • 1185 views
I'm following introductory course on Embedded AI, the course used Cube-Mx AI  3.4.0 AI Package, which generated a 'Data Processor .c' file. we need the file to insert user code for our application. But no where in the file structure in the up-to-date 9.0.0 could be found. Please advise if there is equivalent file in the generated code.
Best regards
ksale.1
ksale.1Author
Senior II
June 21, 2024
I'll continue with the assumption this Data-Process file is added to the project not generated by cubeMX. The instructor did not hint this is the case.
