December 7, 2023
CMSIS DSP library in machine learning with cube Ai
  • Hi I am trying to use the FFT function of CMSIS DSP library, along with X-Cube-Ai on Cube IDE 1.10.1
  • As i try to use the FFT feature, while using TensorFlow lite, it gives multiple error. Is there any way to use the FFT feature with Cube Ai ?
fauvarque.daniel
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
