Aug 20, 2024 3:23 AM UTC
Class in the output of the refernece model
When I used validation app I could see like
 notes: - the output of the reference model is used as ground truth/reference value
        - 10 samples (5 items per sample)
  acc=100.00%, rmse=0.000000147, mae=0.000000066, l2r=0.000000430, nse=1.000, cos=1.000
  5 classes (10 samples)
  C0        0    .    .    .    .
  C1        .    0    .    .    .
  C2        .    .   10    .    .
  C3        .    .    .    0    .
  C4        .    .    .    .    0
Now I'm writing a inference code by using template app.
How can I process output to know what class is the input data?
fauvarque.daniel
fauvarque.danielBest answer
Aug 28, 2024 9:19 AM UTC
This document Documentation/embedded_client_stai_api_example.html in the embedded documentation gives you example on how to get the output.
Then the way to process it really depends on your network and the output types (float, int)
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
fauvarque.daniel
