Benchmarks Fail to Run After NEAI 5.0.0/1 Update
- 5 replies
- 848 views
Greetings!
After updating to the latest v5 of NEAI yesterday, benchmarks have failed to cross the initial step of loading in the first library. I suspect this has to do with the number of cores/ threads and memory being allocated to the NEAI process, as the 3221225773 and 3221225794 pwsh codes are dumped in the logs. For reference, my system has a Ryzen 7 4800H and 16 GB of RAM onboard, which hasn't had an issue with running benchmarks in previous versions.
Updating to the new 5.0.1 version released earlier today hasn't fixed the issues either. I've attached my logs below.
