DDutt.3
May 25, 2023
After converting my TensorFlow Lite model using Cube.AI as I save my project, the Middleware is not generated. Can anyone help me regarding this?
fauvarque.daniel
First make sure that you don't have any error when you click on the analyze button.
If no error, you may have hit a issue seen with recent version of STM32CubeMX where the middleware directory is deleted upon project regeneration.
To workaround the issue, uncheck the checkbox "Delete previously generated files when not regenerated" under Project Manager -> Code Generator -> Generated Files
In X-CUBE-AI 8.1 we make sure to restore the deleted files if they are needed post code generation by STM32CubeMX
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
