AVM
Jan 18, 2022 9:24 AM UTC
With any of the optimization levels (-Os size/-O1 general/-O2 speed/-O3 fast) except -O0 none, bootloader is not jumping to the application code.
I am working on SPC58NG84E7 bootloader. I have BL code(at 0xFC0000) which jumps to the APP location 0xFD0000 after waiting for 10sec after startup and executes the code there. Both codes have optimization NONE(-O0).
But when BL optimization changed to -Os size or any of the mentioned, BL is not jumping to the APP and continuously running the BL code.
What could be the issue here?
Regards,
AM
    mƎALLEm
    mƎALLEmBest answer
    Jan 18, 2022 9:43 AM UTC
    @AVM​ ,
    Think about an optimized variable(s) and use volatile ..
    SofLit
    mƎALLEm
    mƎALLEmBest answer
    @AVM​ ,
    SofLit
    AVM
    AVMAuthor
    Jan 19, 2022 6:47 AM UTC
    Thanks SofLit!
    This helped in resolving the issue.
    mƎALLEm
    Jan 19, 2022 8:25 AM UTC
    Thank you for the feedback.
    Please close this post by clicking the "Select as Best" button in the above answer. This will help other community members to find the solution more quickly.
    Thank you.
    SofLit
