zeke.huang
Jun 18, 2019 2:35 AM UTC
Why program loop in the function of irqSysHalt() ?
The program has been in irqSysHalt at the time of clock initialization, the clock initialization failed, but I don't know why? Has anyone encountered a similar problem?
Program clock init fail:
The figure below is the clock configuration:
    zeke.huang
    zeke.huangBest answer
    Jun 28, 2019 2:20 AM UTC
    Hi, Erwan
    Thank you for your reply.
    The problem has been solved.
    Best regards
    zeke
    Erwan YVIN
    Jun 27, 2019 2:39 PM UTC
    Hello ,
    Sorry , i do not see any screenshot.
    your PC (program counter) should show irqSysHalt
    with the debugger you can check LR (Link register)
    check the clocktree in SPC5Studio.
    Best regards
    Erwan
    zeke.huang
    zeke.huangAuthorBest answer
    Hi, Erwan
    Best regards
    zeke
    DKuma.3
    Jul 26, 2021 9:33 AM UTC
    Hi Zeke,
    I have the same problem of irqSysHalt while clock initialization.
    Could you please explain how did you solve the problem.
    Thanks in advance
    Dipak
