zeke.huang
Aug 30, 2019 2:02 AM UTC
Why errors [Error: unrecognized opcode: `mov'] occurred while compiling
Hi all,
Dear all ST's expert, somebody help me out, Thank you very much.
An errors occurred while compiling, see below:
assembler code:
build result:
​IDE: SPC5 Studio, version: 5.8.1
Compiler: FreeGCC with VLE support
or Hightec Pro
    Erwan YVIN
    Erwan YVINBest answer
    Aug 30, 2019 8:05 AM UTC
    Hello ,
    Which core do you use ?
    you should refer to e200z0RM.pdf , e200z3RM.pdf or e200z4RM.pdf
    Best Regards
    Erwan
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
    zeke.huang
    Aug 30, 2019 9:09 AM UTC
    Hi Erwan,
    I am using SPC560B50L1.
    Best Regards
    zeke
    Erwan YVIN
    Sep 2, 2019 2:32 PM UTC
    Hello ,
    SPC560B50L1 is part of e200z0 family
    "The e200z0h core is a single-issue, 32-bit Power Architecture technology VLE-only design
    with 32-bit general purpose registers (GPRs). All arithmetic instructions that execute in the
    core operate on data in the general purpose registers (GPRs).
    Instead of the base Power Architecture technology support, the e200z0h core only
    implements the VLE (variable-length encoding) APU, providing improved code density."
    For assembler code , please refer to the document e200z0RM.pdf
    Best Regards
    Erwan
