Angelo CastelloBest answer
Jan 18, 2021 3:27 PM UTC
Could you please verify that project build was successful completed ?
To verify that you navigate into your project and you should found the out.elf file under build directory, (see the attached example picture).
In case not built you must do it clicking on "Compile your application" available into "Common Task view".
After that you should able to burn on the target board and debug it.
Let me know.
Angelo
