CGilm.1
Oct 14, 2021 8:17 PM UTC
Watchdog after WD reset
After the watchdog does a reset and the watchdog is enabled after the reset the watchdog will not cause a reset. The watchdog is enabled and not getting serviced but a reset is not occurring. What has to be done to get the watchdog working again?
    ODOUV.1
    Nov 18, 2021 4:23 PM UTC
    if you had a first RESET due to the watchdog, it means it was well programmed and the IP worked as expected.
    Is the SWT programmed the same manner after the RESET ?
    Which SPC5 MCU/board do you use ?
    Did you try the corresponding SWT demo from SPC5Studio tool ? (eg "SPC582Bxx_RLA SWT Test Application for Discovery")
    -Olivier
    CGilm.1
    CGilm.1Author
    Nov 18, 2021 4:34 PM UTC
    When I was first running the program the watchdog was hitting the first time. After the first watchdog reset the watchdog would not cause a reset. After a while, running the same code, the watchdog would not set even the first time. I tried the "SPC582Bxx_RLA SWT Test Application for Discovery" code and it had the same behavior. The watchdog would set once then not set again. Shahrukh ASHRAF (shahrukh.ashraf@st.com) who I contacted tried and had the same behavior. I am using SPC58NG-DISP board. Craig Gilmore Sent from Mail<> for Windows
    ODOUV.1
    Nov 19, 2021 1:49 PM UTC
    I saw your issue is managed by ST support by Shahrukh who has already reproduced.
    I let you with him.
    Best regards,
    -Olivier
