Angle
Jul 27, 2022 5:58 AM UTC
undeclared identifier error
Hi, can i know how to solved this error?
    ODOUV.1
    Aug 2, 2022 8:31 AM UTC
    this SD1 is the first instance of serial driver corresponding to the first HW instance Linflex0 configured in serial:
    if you chose another HW instance in your application, your code must use another Driver instance too.
    Look at the begining of serial_lld.c:
    #if (SPC5_LINFLEX0_SETTING == SPC5_LINFLEX_MODE_SERIAL) || defined(__DOXYGEN__)
    SerialDriver SD1;
    #endif
    #if (SPC5_LINFLEX1_SETTING == SPC5_LINFLEX_MODE_SERIAL) || defined(__DOXYGEN__)
    SerialDriver SD2;
    #endif
    Best regards
