AChan.5.20
Jun 17, 2019 7:01 AM UTC
Unable to run code on SPC560B40L3
Hello
   I was trying to run Sample Test Code from application wizard into my ECU(SPC560B40L3) but it doesn’t worked out.
I’ve attached the snapshot. Could you please help me out into this?
    Erwan YVIN
    Erwan YVINBest answer
    Jun 27, 2019 2:42 PM UTC
    Hello ,
    it seems to be a crash issue
    check LR,R14 in the debugger to check where the crash is located.
    the error display c:\SPC5Studio\tmp
    are you the right to access to this directory ?
    Best regards
    Erwan
    Erwan YVIN
    Hello ,
    Best regards
    Erwan
