hans536
Dec 27, 2022 7:20 AM UTC
UDE STK question.
I use a UDE STK .
How do I check the value of a variable after creating a Braek Point ????​
ODOUV.1
Jan 3, 2023 4:36 PM UTC
If your variable is global,
then you need to check its address and dump the memory.
if your variable is local,
then you need to break at good instruction and check the good register.
Best regards.
