yakdagg
Sep 29, 2021 11:45 AM UTC
Timers and Interrupts
i m working with SPC584xxx series MCU and trying to work with timers interrupts.
using 1ms timer for calculating times for operations and using 10ms timer for work.
but when 10ms timer work, 1ms timer is waiting and not triggering until 10ms timers work done.
i just wanna see the how the priorities are working but i couldn't get what i want.
i made all settings via gui and adding callbacks manually.
should i add something else?
    Erwan YVIN
    Erwan YVINBest answer
    Sep 29, 2021 12:54 PM UTC
    Hello ,
    There is an example application in SPC5Studio tools suite :
    SPC584Bxx_RLA PIT Test Application for Discovery
    the priority is set in Low Level drivers component
    You can find all the information in the Reference Manual RM0449
    Best Regards
    Erwan
    Erwan YVIN
    Hello ,
    Best Regards
    Erwan
    yakdagg
    yakdaggAuthor
    Sep 30, 2021 12:01 PM UTC
    i saw this example but it s not about priorities. i tried change priorities manually from IRQ Priority Settings which you share ss but they're not cutting processes.
    as example
    task2_{ >10ms timer >IRQ Priority 16
    some processes +2ms
    task_1{>1ms timer >IRQ Priority 8
    counter++
    at this scenario, "task_1" should cut "task_2" least 2 time and counter should increase. but it is not working.
    by the way, timer registers are counting at backplan but interrupts are not triggering.
    Erwan YVIN
    Sep 30, 2021 1:11 PM UTC
    Sorry ,
    it is well PIT channel priority (cf tooltip) (cf help section)
    PIT = Periodic Interrupt Timer
    could you try to enable the switch :
    OSAL_ENABLE_IRQ_PREEMPTION ?
    Best Regards
    Erwan
    yakdagg
    yakdaggAuthor
    Sep 30, 2021 1:19 PM UTC
    it's default value is FALSE but tried with both option which TRUE and FALSE. unfortunately results are same.
    yakdagg
    yakdaggAuthor
    Oct 12, 2021 1:21 PM UTC
    no more help ? any other solution? maybe a misspoint?
