Yqiu.1
Nov 21, 2020 1:54 PM UTC
there is some problem in SPI config based on SPC58NN
0693W000005CC3uQAG.png0693W000005CC3zQAG.pnghello guys, I want to config SPI to communicate with TJA1145 .the 4 pins are shown in the picture.
but I test the signal by OScilloscope and I found nothing in the four pin which means no meaningful signal. for example the CS pin is always high and no pulse signal in SCK pin.
I list majority signals here , could you pls help me to analysis the config and whether I miss something?
thanks in advance.
    Erwan YVIN
    Erwan YVINBest answer
    May 24, 2022 12:17 PM UTC
    Sorry for the late answer ,
    i recommend you to check the corresponding RM (reference manual) of SPC58NN.
    Best Regards
    Erwan
    Erwan YVIN
    Best Regards
    Erwan
