Feb 25, 2025 2:37 AM UTC
The high level voltage of the pin
I am currently using the SPC58EC series of microcontrollers. I would like to know, for an I/O (configured in input mode), at what input voltage level it will be recognized as a high level. Is this voltage value configurable? Thank you for your reply. Thank you.
Erwan YVIN
Erwan YVINBest answer
Mar 3, 2025 9:12 AM UTC
Hello ,
I recommend to check the following data sheet
Datasheet - SPC584Cx, SPC58ECx - SPC58 C Line - 32 bit Power Architecture automotive MCU Dual z4 cores 180 MHz, 4 MBytes Flash, HSM, ASIL-B
   Best regards
             Erwan
Erwan YVIN
Hello ,
   Best regards
             Erwan
