Oct 10, 2026 12:59 AM UTC
SR6P6C6 HSM enable DCF write in wrong place
Hello, I mistakenly programmed the HSM enable record into the host core DCF area at address 0x29F81A10. Could this introduce any risk of incorrect configuration?
I found that I can overwrite the incorrect DCF record by programming all 0xFF. However, I am concerned that the programmed 0xFF may differ from the 0xFF of an unprogrammed blank device. Could you advise whether this operation is valid?
muchCAuthor
Oct 10, 2026 5:17 AM UTC
Sorry I posted the Stella chip thread in the STM32 section, and I cannot change the section now.
muchCAuthor
Oct 11, 2026 3:42 PM UTC
can someone help?
muchCAuthor
Oct 15, 2026 2:08 AM UTC
Could you please arrange technical support to help clarify this for me?
Oct 22, 2026 8:52 AM UTC
HSM is module for hardware security. For HSM enable record info, do you mean any information before send to HSM or after
muchCAuthor
Oct 23, 2026 12:56 AM UTC
A Security DCF record 0x0004000600000043 should be write at HSM UTEST(0x2437D000-0x2437DFFF) to enable HSM module. My customer mistakenly write the record at HOST UTEST(0x29F81000-0x29F83FFF) .I found that I can overwrite the incorrect DCF record by programming all 0xFF,will that work?
