PLEE.2
Feb 9, 2023 5:40 AM UTC
spc5studio makefile modify
Hello.
i use SPC5Studio tool
i started import samples from application library / Bootloader ...
the project complie is ok.
i modified Makefile.
i know this file automatically generated
but i must modify the compile option
"HEX = $(U_GHS_PATH)gsrec -hex386" to "HEX = $(U_GHS_PATH)gsrec -hex386 -crc32"
and then, this compile is ok.
​but. If i generate it again, the additional option disappears (-crc32).
prevent the makefile from being regenerated,
I want to put an option in the place that creates the makefile.
thanks
    ODOUV.1
    ODOUV.1Best answer
    Feb 9, 2023 9:49 AM UTC
    supposing you are working on SPC58ECxx
    just modify your file:
    C:\SPC5Studio-6.0\eclipse\plugins\com.st.tools.spc5.components.platform.spc58ecxx_rla_1.18.0.20221220104647\component\root_wa\Makefile.ftl
    It will generate your Makefile with your new parameter each time (on ALL your SPC58ECxx projects!!!)
    Best regards.
    ODOUV.1
    ODOUV.1Best answer
    Best regards.
