Caio Gubel
Jun 30, 2018 2:28 AM UTC
SPC5Studio example application Error: Cannot load configuration file 'L/SPC56ELxx_RLA ADC Test Application for DiscoveryPlus/configuration.xml':
Posted on June 30, 2018 at 04:28
Hello (I am new to ST and SPC5Studio)
I just used the SPC5Studio Application Wizard to import the SPC56ELxx_RLA ADC Test Application for DiscoveryPlus and when I tried to generate it it showed the following error:
/SPC5-Config/application/instances/instance[7]/pit_settings/channel_0/frequency: Required Field.
I tried repeating the process with the SPC56ELxx_RLA CAN Test Application for DiscoveryPlus with similar results. I can see a small 'x' in front of the configuration.xml file in the project explorer in both cases.
I really appreciate if someone could help me with this.
Thanks!
#cannot-load-configuration-file
    Erwan YVIN
    Erwan YVINBest answer
    Jul 2, 2018 8:07 AM UTC
    Posted on July 02, 2018 at 10:07
    Hello Caio ,
    Could you send me the Installation details ?
    Could you update SPC5-RLA
    http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates5
     Best regards
                  Erwan
    Erwan YVIN
    Hello Caio ,
     Best regards
                  Erwan
    Caio Gubel
    Jul 9, 2018 1:25 AM UTC
    Posted on July 09, 2018 at 03:25
    Thanks for answering Erwan. I reinstalled it all and somehow it is now working - thanks for your reply and please accept my apologies for my delayed comment -  It was my fault that I didn't check it before - I was used with another system from another company that alerted (email) when a question got replied or commented and it just went over my head.
