sebastian239955
SPC5Studio 4.1.0 compilation errors from generated code
Posted on April 27, 2016 at 09:34
When I use SPC5Studio 4.1.0 to generate files for a project that worked with 4.0.0 and try to compile with gcc, I get the following error
scc1.exe: error: bad value (e200z0) for -mcpuIf I replace the line in the Makefile
MCU  = e200z0 -meabi -msdata=none -mregnameswith the previous code from 4.0.0
MCU  = e200zx -meabi -msdata=none -mnew-mnemonics -mregnamesit works again.
Likewise, in the file checkCompiler.h I have to add the line
&sharpdefine se_bge   bgeoutside of the &sharpif defined(__hightec_asm), otherwise I get this error:
./components/spc560bcxx_platform_component_rla/lib/src/boot.s:163: Error: Unrecognized opcode: `se_bge'
#spc5studio
    Erwan YVIN
    Posted on April 27, 2016 at 10:00
    Hello Sebastian ,
    on SPC5Studio 4.1.0,
    if you have updated HAL & RLA , you must update the freegcc 4.9.2 too.
    e200zx option is for the old compiler 4.6.1
    e200z0 option  is for the is for the new compiler 4.9.2.
    i recommend you to switch on the new compiler
    This release of gcc for e200-VLE supports the ''Power Architecture® 32-bit Application Binary Interface Supplement 1.0 - Embedded''. It is based on gcc 4.9.2, binutils 2.24 and gdb 7.8.
                      Best Regards
    Erwan
    sebastian239955
    Posted on April 27, 2016 at 10:20
    Hello Erwan,
    thanks for your quick reply.
    In the SPC5 Studio Market place, the Free PowerPC-VLE GCC 4.9.2 is installed and the update option is greyed out.
    Did something go wrong with the update maybe?
    Erwan YVIN
    Posted on April 27, 2016 at 10:42
    Hello Sebastian ,
    Could you give me your installation details ?
    you should have (cf screenshot)
    Best regards
    Erwan
    ________________
    Attachments :
    2016-04-27_104038.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWry&d=%2Fa%2F0X0000000boZ%2FDlKdT220ZsfP3VJqTkDtf.0pjUcI3zzhGLZ0gO9MphQ&asPdf=false
    Erwan YVIN
    Posted on April 27, 2016 at 10:43
    Hello Sebastian ,
    Do you use hightec or freegcc ?
    After updating , Old projects should be cleaned first
    Best Regards
                               Erwan
    sebastian239955
    Posted on April 27, 2016 at 11:20
    Hello Erwan,
    I'm using
    after uninstalling and reinstalling freegcc 4.9.2 the previous errors are gone.
    My install looks like this:0690X00000604toQAA.png
    After cleaning and regenerating, I get the following errors when compiling:
    make all
    Compiler Options
    ppc-freevle-eabi-gcc -c -mcpu=e200z0 -meabi -msdata=none -mregnames -mvle -O2 -ggdb -fomit-frame-pointer -falign-functions=16 -msoft-float -ffunction-sections -fdata-sections -fno-common -Wall -Wextra -Wstrict-prototypes -Wa,-alms=build/lst/ -DPPC_USE_VLE=1 -DCOMPILER=8 -DBOARD=230 -DMCAL=60 -MD -MP -MF .dep/build.d -I. -I./components/spc560bcxx_platform_component_rla/lib/include -I./components/spc560bcxx_board_initialization_component_rla/lib/include -I./components/spc560bcxx_clock_component_rla/lib/include -I./components/spc560bcxx_irq_component_rla/lib/include -I./components/spc560bcxx_low_level_drivers_component_rla/lib/include -I./components/spc560bcxx_platform_component_rla/cfg -I./components/spc560bcxx_board_initialization_component_rla/cfg -I./components/spc560bcxx_clock_component_rla/cfg -I./components/spc560bcxx_irq_component_rla/cfg -I./components/spc560bcxx_low_level_drivers_component_rla/cfg -I./components [...] main.c -o main.o
    mkdir -p build/obj
    mkdir -p build/lst
    Compiling boot.s
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s: Assembler messages:
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:40: Error: Illegal instruction for VLE mode: `bl'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:42: Error: Illegal instruction for VLE mode: `bl'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:68: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:111: Error: Illegal instruction for VLE mode: `lis'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:112: Error: Illegal instruction for VLE mode: `ori'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:113: Error: Illegal instruction for VLE mode: `lis'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:114: Error: Illegal instruction for VLE mode: `ori'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:117: Error: Illegal instruction for VLE mode: `bge'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:118: Error: Illegal instruction for VLE mode: `stmw'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:119: Error: Illegal instruction for VLE mode: `addi'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:120: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:126: Error: Illegal instruction for VLE mode: `li'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:129: Error: Illegal instruction for VLE mode: `blr'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:138: Error: Illegal instruction for VLE mode: `lis'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:139: Error: Illegal instruction for VLE mode: `ori'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:143: Error: Illegal instruction for VLE mode: `lis'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:144: Error: Illegal instruction for VLE mode: `ori'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:147: Error: Illegal instruction for VLE mode: `blr'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:153: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:155: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:157: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:159: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:161: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:163: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:165: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:167: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:169: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:171: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:173: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:175: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:177: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:179: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:181: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:183: Error: Illegal instruction for VLE mode: `b'
    ./components/spc560bcxx_platform_component_rla/lib/src/boot.s:210: Error: Illegal instruction for VLE mode: `b'
    make: *** [build/obj/boot.o] Error 1
    Erwan YVIN
    Posted on April 27, 2016 at 11:46
    Hello Sebastian ,
    Your installation is correct.
    but your boot.s is still the old one after regeneration.
    your clean procedure is not ok.
    did you use clean procedure by Activity Wizard ?
    (cf screenshot)
    you can remove by hand your components directory in your application
    Best regards
    Erwan
    ________________
    Attachments :
    2016-04-27_114359.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qXVA&d=%2Fa%2F0X0000000boo%2FyP2nyBlXmmQt5GSFS1oYSVnyv9IauZU2QYSMSxRGmak&asPdf=false
    sebastian239955
    Posted on April 27, 2016 at 14:30
    Hello Erwan,
    the boot.s file had been patched with the old code, after I removed the patch the error disappeared. Thank you.
    Unfortunately, I still get errors from the code in my user.mak.
    I structured the wildcard includes the same way as in the makefile, but with gcc 4.9.2 there seems to be a problem in that all of my externally included files are not found:
    14:10:13 **** Build of configuration Default for project Console_Switch_SPC560B40L3_11 ****
    make all
    Compiling boot.s
    Compiling crt0.s
    Compiling ivor.s
    Compiling vectors.s
    Compiling pal.c
    Compiling clock.c
    Compiling irq.c
    Compiling spc5_lld.c
    Compiling adc_lld.c
    Compiling can_lld.c
    Compiling spc5_emios.c
    Compiling icu_lld.c
    Compiling pwm_lld.c
    Compiling serial_lld.c
    Compiling board.c
    Compiling irq_cfg.c
    Compiling adc_lld_cfg.c
    Compiling can_lld_cfg.c
    Compiling icu_lld_cfg.c
    Compiling pwm_lld_cfg.c
    make: *** No rule to make target `CHALSPC5.c', needed by `build/obj/CHALSPC5.o'.  Stop.
    14:10:28 Build Finished (took 15s.39ms)
    I used wildcard includes in user.mak like the ones in the Makefile like so, and it worked with the old gcc:
    rwildcard = $(wildcard $1$2) $(foreach d,$(wildcard $1*),$(call rwildcard,$d/,$2))
    AUTO_C_MODULES = $(call rwildcard,D:/<path>/,*.c)
    AUTO_C_MCAL = $(call rwildcard,D:/<path>/,*.c)
    AUTO_C_BOARD = $(call rwildcard,D:/<path>/,*.c)
    AUTO_C_APP = $(call rwildcard,D:/<path>/,*.c)
    AUTO_INC_MODULES = $(sort $(dir $(call rwildcard,D:/<path>/,*)))
    AUTO_INC_MCAL = $(sort $(dir $(call rwildcard,D:/<path>/,*)))
    AUTO_INC_BOARD = $(sort $(dir $(call rwildcard,D:/<path>/,*)))
    AUTO_INC_APP = $(sort $(dir $(call rwildcard,D:/<path>/,*)))
    # List of all user C source files
    U_C_SRC     = $(AUTO_C_MCAL) $(AUTO_C_MODULES) $(AUTO_C_BOARD) $(AUTO_C_APP)
    # List of all user C++ source files
    U_CPP_SRC   =
    # List of all user ASM source files
    U_ASM_SRC   =
    # List all user C define here, like -D_DEBUG=1
    UDEFS       = -DCOMPILER=8 -DBOARD=231 -DMCAL=60
    # add same options in paths and symbols for eclipse
    # Define ASM defines here
    UADEFS      =
    # List all user directories here
    UINCDIR     = $(AUTO_INC_MODULES) $(AUTO_INC_MCAL) $(AUTO_INC_BOARD) $(AUTO_INC_APP)
    # List the user directory to look for the libraries here
    ULIBDIR     =
    # List all user libraries here
    ULIBS       =
    The verbose compile shows the include directories correctly like:
    ppc-freevle-eabi-gcc -c -mcpu=e200z0 -meabi -msdata=none -mregnames -mvle -O2 -ggdb -fomit-frame-pointer -falign-functions=16 -msoft-float -ffunction-sections -fdata-sections -fno-common  -Wall -Wextra -Wstrict-prototypes -Wa,-alms=build/lst/pwm_lld_cfg.lst -DPPC_USE_VLE=1 -DCOMPILER=8 -DBOARD=231 -DMCAL=60 -MD -MP -MF .dep/pwm_lld_cfg.o.d -I. -I./components/spc560bcxx_platform_component_rla/lib/include -I./components/spc560bcxx_board_initialization_component_rla/lib/include -I./components/spc560bcxx_clock_component_rla/lib/include -I./components/spc560bcxx_irq_component_rla/lib/include -I./components/spc560bcxx_low_level_drivers_component_rla/lib/include -I./components/spc560bcxx_platform_component_rla/cfg -I./components/spc560bcxx_board_initialization_component_rla/cfg -I./components/spc560bcxx_clock_component_rla/cfg -I./components/spc560bcxx_irq_component_rla/cfg -I./components/spc560bcxx_low_level_drivers_component_rla/cfg -I./components -ID:/<path1>/ -ID:/<path2>/ ./components/spc560bcxx_low_level_drivers_component_rla/cfg/pwm_lld_cfg.c -o build/obj/pwm_lld_cfg.o
    Do you have any idea what could have caused this?
    Erwan YVIN
    Posted on April 27, 2016 at 14:59
    Hello Sebastian ,
    a Makefile issue.
    Could you try with our old gnutools ?
    1) Perform a backup of
    c:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.tools.gnu.win32_1.0.0.201604221501\gnu\bin\
    2) copy the contents of the zip files in
    if there is no secret inside , could you send me your application ?
    otherwise use my direct email.
    Best regards
    Erwan
    ________________
    Attachments :
    gnutools.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qYr7&d=%2Fa%2F0X0000000bp5%2FLqATvPOPPIuarxReMCu9s0QU_W7URwr.mLNbwfy98xc&asPdf=false
    sebastian239955
    Posted on April 27, 2016 at 16:23
    Hello Erwan,
    the old gnutools worked, thank you for your excellent support!
    Unfortunately, the project contains our whole IP stack and I can't send it to you.
    If I can help you to find a fix for the Makefile issue in another way, contact me anytime.
    Erwan YVIN
    Posted on April 27, 2016 at 18:03
    Hello Sebastian ,
    Good to know  ;)
    it is a regression , we will generate a SPC5Studio 4.1.1 to revert our version of gnutools.
    the new one was based on zimsis (cf http://sourceforge.net/projects/mingw.)
       Best regards
                         Erwan
