SKara.7
Jan 17, 2022 11:17 AM UTC
SPC58xxx - How to change the frequency of external oscillator in SPC5 Studio Clock Tree editor?
In our project, we are using a 20Mhz external crystal oscillator. The default frequency of external oscialltor in SPC5 Studio CLock Tree editor is 40Mhz. How will I change it to 20Mhz? Please see the picture below.
Br,
Sreejith
    ODOUV.1
    ODOUV.1Best answer
    Jan 17, 2022 1:29 PM UTC
    click on Clock Component:
    then on oscillator setting in outline:
    0693W00000JMEOqQAP.pngYou will reach the oscillator settings in the main window:
    Then change it to 20 MHz and you will have to adapt all your clock tree using reference manual according to your new external clock.
    Best Regards,
    -Olivier
    ODOUV.1
    ODOUV.1Best answer
    Best Regards,
    -Olivier
    ODOUV.1
    Jan 28, 2022 7:54 AM UTC
    did it work as you expected ?
    Best Regards,
    -Olivier
    SKara.7
    SKara.7Author
    Jan 28, 2022 9:16 AM UTC
    Hi Olivier,
    I am successful in changing the external clock value as you suggested. But, I am running into trouble with the clock tree configuration.
    Best regards,
    Sreejith
    ODOUV.1
    Jan 28, 2022 10:07 AM UTC
    Thank you,
    then would you please tag as "best answer" my answer to this topic.
    And enter a new topic for your new issue/question.
    Best Regards,
    -Olivier
