Jun 17, 2024 6:57 AM UTC
SPC58X MCAL the error appear ADC Moudle:Invaild Xpath-expression for Attribute
The error will appear when I configurate the module of AdcGroupDefinition, but the port and the hardware channel are configuarted correctly and conform.
How can i solve this problem from the picture?
category : Error
project : Cho6M_Gpt_rtm2
description: Invalid XPath-expression for Attribute "INVALID" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/Adc/ELEMENTS/Adc/AdcConfigSet/AdcConfigSet_0/AdcHwUnit/AdcHwUnit_0/AdcGroup/AdcGroup_0/AdcGroupDefinition/__5": (1818) No value found for object ""
detailed : Invalid XPath-expression for Attribute "INVALID" of node "<a href="datamodel://Cho6M_Gpt_rtm2?/AUTOSAR/TOP-LEVEL-PACKAGES/Adc/ELEMENTS/Adc/AdcConfigSet/AdcConfigSet_0/AdcHwUnit/AdcHwUnit_0/AdcGroup/AdcGroup_0/AdcGroupDefinition/__5">/AUTOSAR/TOP-LEVEL-PACKAGES/Adc/ELEMENTS/Adc/AdcConfigSet/AdcConfigSet_0/AdcHwUnit/AdcHwUnit_0/AdcGroup/AdcGroup_0/AdcGroupDefinition/__5</a>": (1818) No value found for object ""
resource :
path : /AUTOSAR/TOP-LEVEL-PACKAGES/Adc/ELEMENTS/Adc/AdcConfigSet/AdcConfigSet_0/AdcHwUnit/AdcHwUnit_0/AdcGroup/AdcGroup_0/AdcGroupDefinition/__5
stack :
螢幕擷取畫面 2024-06-17 144417.png螢幕擷取畫面 2024-06-17 144342.png螢幕擷取畫面 2024-06-17 144906.png
Erwan YVIN
Erwan YVINBest answer
Jun 17, 2024 9:31 AM UTC
Hello , I have forwarded your point to Autosar Team
Just for info , AUTOSAR is not a mass market topic to address in this forum, it is better to contact local support.
   Best Regards Erwan
Erwan YVIN
   Best Regards Erwan
FuKaiAuthor
Jun 21, 2024 8:21 AM UTC
Hi, thank you for your reply.
Is there any sample project for EB Tresoe about adc module I can refer?
Or I can supply my project for you to debug the problem.
Now, I am developing SPC58EG MCU.
Thank you.
