SMuru.1
Jun 25, 2021 3:08 PM UTC
SPC58NG BAF configuration DCF Register - Modify BAF_BYPASS using Lauterbach debugger
Could the BAF_BYPASS field in the BAF configuration DCF register by modified by the user.
If yes, under which module can I find it? I'm unable to find this in Lauterbach debugger.
If no, how can I skip the BAF section during the bootup? - My device has pre-programmed BAF region.
Thanks!
    Erwan YVIN
    Erwan YVINBest answer
    May 6, 2022 1:18 PM UTC
    Hello ,
    sorry for the late answer ,
    in our team ,
    i recommend to check this document and to add some addional commands in the cmm scripts
    https://www2.lauterbach.com/pdf/debugger_mpc5500.pdf
    Best Regards
    Erwan
    Erwan YVIN
    Hello ,
    in our team ,
    Best Regards
    Erwan
