SGeno.1
Nov 9, 2020 11:20 AM UTC
SPC58Ex PWM setting. Someone could me help with a SPC5 Studio setup and code as well?
    Giuseppe DI-GIORE
    Nov 13, 2020 3:22 PM UTC
    Please have a look at SPC5Studio PWM demos.
    Just for info:
    SPC582B: PWM is generated using eMIOS
    SPC584B: PWM is generated using eMIOS
    SPC58EC: PWM is generated using eMIOS
    SPC58xG: PWM is generated using eMIOS
    SPC58xE: PWM is generated using GTM (install GTM plugin)
    SPC58NN: PWM is generated using GTM (install GTM plugin)
    Regards,
    Giuseppe
    SGeno.1
    SGeno.1Author
    Nov 13, 2020 5:06 PM UTC
    Hi Giuseppe.
    Thanks an example installed in the SPC5 Studio "SPC58ECxx_RLA PWM-ICU Test Application" the pwm took place in my evaluation board.
    SPC5 studio setting and main.c code as well, are now perfect clear.
    Thank you.
    Santino
